Leeds, North Dakota | 2005 buhler 2425 i believe, tractor was warmed up, we had discussed this in shop, had ball style on flowrater, changed tips, made a difference, if you need a little more flow makes a difference, don't buy cheap ones, junk, yes need to protect tips, can be a sob, if damaged, had a customer that had got tillage winded up, no locks, have to use a chain to frame to bleed line off due to a bad coupler, pain, customer said well worked fine on other tractor, checked all remotes, well bad tip, its darn tough trying to keep dirt out, drop hoses, can really pi's ya of, scott. | |
