| Might check with your dealer on how you have the hydraulics plumbed on your tractor. We noticed the same warning screens coming up on the GS2. When we rotated meters manually motor number 2 would fail 2 out of 10 times. When we watched the variable rate motor 2 at the same time as we rotated meters the chain would jump and skip around, but motor #1 was fine. We ended up diagnosing the return lines were plugged into the SCVs, instead of into the case drains, resulting in the oil getting too hot. Once the tech plumbed all of the return lines into the case drain, the problem went away. This was on a 2010 1770 CCS 24R30 with Row Command with a 8345R tractor. | |
