| I don't think that is for the open door chime. Only for the seatbelt chime. There is a spade connector that the 1 wire goes to on the key tumbler assembly. You might have to take the top half of the steering column cover off to see it, but unplug it and no more open door chime. I've always just cut the wire, but if you want to put it back to stock you can pull the connector. It's just a little more work to get to it. | |
