Posted 5/11/2010 03:02 (#1193818 - in reply to #1193367) Subject: Re: 8100 JD Auto Steer Sensor
What it is, is that the JD SSU can see motion in the WAS (wheel angle sensor) and it knows the steering wheel hasn't been moved and that it has not commanded anything so it throws the code. I will look up the correct procedure for an 8x00 and get back to you. It will involve deleting the SSU from the ICU and pulling the fuse I think, will confirm soon.
