Vandalia, IL | Have a 99 Int. semi tractor w/ N14 cummins using Cellect electronic fuel system. Truck seems to be derating itself. Showing error code 23. Error code is for intake pressure sensor. Replaced with a known good sensor out of an 8.3L Cummins in an MX240. Sensors appeared to be exactly the same. Ran engine for a short time. Plenty of boost and no fault codes. Does anyone know of any reason why I couldn't order a sensor for thru CNH parts instead of cummins dealer? (CNH dealer alot closer and cheaper.) | |
