Central WI | If you have access to streamer bars, use those in a seperate pass and you can apply 32% N straight. I put 30 gal on the other day before a rain and had a very slight burn. Guys from local coop think im nuts, but it worked great. Wouldnt apply right after a rain when the wheat leaves are still wet though as it does seem to burn more. Either way it still didnt burn as much as when i used to apply 12 gal N/ 8gal water +herbicide. I just have to make another pass. | |
