Posted 5/7/2010 11:04 (#1188867 - in reply to #1188814) Subject: Re: JD ITC / 2600 to Flexi-Coil Flexcontrol GPS signal ??
west central IL.
The PF90350 will let you take the NEMA output from a Deere receiver to another brand of equipment. It uses a 9 pin db connector to do it. If your flexcontrol box has a place for a 9 pin db connection, it should work. You might need a gender changer or a null modem and you will also need to know from your other equipment what baud rate to use and what NEMA strings to turn on in the Deere receiver.
