Dietrich, Idaho and Mountain Home, Idaho | Like amc4life said, try curved ab. When I had my smartsteer set to 30 it made the tractor(JD 4250) steer right past the guidance line. In fact it never picked the line up, all it would do was steer(in a very straight line) at an angle to the lines. Once I set it back to 10 it worked good. I have it set at 8 now and it works awesome. That is on a FS tractor and your machine is a whole different animal so it may not be best to use a low number. Just keep trying and BE PATIENT(I know it is hard sometimes, been there done that) and you will get it figured out. |
