Martinsville, Ohio | Here is a discussion I found on notill farmer:
Farmer's Forum Discussion
I just purchased a White 5100 planter that was set up by the previous owner for no-till. The planter has a factory-mounted, double-arm coulter with 13-inch Yetter spiked tooth trashwhippers. Should I remove the frame-mounted coulters and switch to the Yetter pin-adjust mounts? (Register For Access.)
Join In The Discussion.
Lightbar Guidance?
Row Cleaners?
http://www.no-tillfarmer.com/pages/forum/White-5100-Frame-Mounted-D... | |
