Posted 4/25/2010 17:36 (#1174257 - in reply to #1174170) Subject: Re: Any way to fake out a Easy guide 500?
There should be a place in the settings for the control valve where it says "close control valve on stop", and you type in yes or no. If you change it to no, then you won't have to reset the rate manually every time, it will stay where it was when you stopped.
