Huntley Montana | Got a GPS? Otherwise you will end up with both sides needing a partial pass with the planter. OR if you want to measure the same distance from the fence with a measuring wheel on both ends to match your planter width, you might come out right on 1 side or the other.
The reason for starting against the fence was so at least 1 side would come out, because with markers & vairing "guess rows" that you never know where you'll end up otherwise. | |
