| I am using a 2600 to map varietys with a 8130 tractor and 1770 planter. I want to try some soy green for high ph areas. The planter has a ground driven pump and I am going to put a two way electric valve in the either sends product back to the tank or out to the units. Is there any way that I can make a coverage map of this that is independent of my variety map and is turned off and on by the switch in the cab? Do I need to open two tabs, one for planting and one for product application? | |
