Missouri | The Kinze population monitor gets its count from the seed tubes and calculates from whatever speed source you have set in your planter monitor setup to give you the actual rate it is planting. The total seeds planted may be a little confusing. When you go to the summary screen or your run screen and get a total seeds planted that is a calculation from the drive of what it thinks it actually planted. If you have your hyd drive set at 27800 it reads what the drive is actually turning while you are planting and calculates the total number of seeds you should have planted according to that. There is no way to get the total number of seeds counted by the PMM module in the monitor itself it just tells you an average while you are planting. If your hyd drive rate and your pop monitor rate dont match then your total applied will not be close to correct. One way to get it closer to right is to change your cal number for the hyd drive to get it closer to what the planter monitor mod is actually reading. Kind of confusing but if you have any questions just ask back. | |
