Ohio | New firmware v3.01 came out today to fix the issue of not mapping variety's with field IQ.
Updates to the firmware of the FmX integrated display for the FieldLevel II system and the Field-IQ™ crop input control system include:
• Improvements to the contour guidance display for the LB25 external lightbar.
• The minimum limit between the LB25 spacing for contour guidance has been lowered back to the value in firmware version 2.00.
• The maximum allowable range of the Autoslope outlet from the last surveyed point has been increased from 20 meters (65 feet) to 50 meters (164 feet).
• An instance in firmware version 3.0 where the loaded Autoslope section line would change when returning to the run screen has been corrected.
• The antenna height allowable range has been increased from 10 meters (32.8 feet) to 100 meters (328 feet), for both single and dual FieldLevel II systems.
• The scroll down of section lines on the Autoslope design screen has been improved.
• Corrected variety tracking with the Field-IQ crop input control system.
• Added user defined high-speed and low-speed warnings for Rawson™ drives.
