Northwest, Ohio | Auxillary electrical outlet has no switched power on CIH 5130MFD. The "always on" side is fine. This is the three prong accessory power located in the side panel. I checked the fuses and relays on both sides of the cowl and they seem to be OK. I can't find for sure which fuse or relay is dedicated to this plug. On the right side, lower right bank, the 7.5 Amp fuse says acc. but that seems a bit light. Any way, it is fine.
I use this to power a Fasse bank to fold the sprayer booms.
Anyone know for sure which fuse to look for? | |
