| Lost the rear ujoint which you know what that does! Broke the flange behind the seal(outside the seal) . Put a new yoke , seal ,whole drive shaft as well as a few other mangled parts so all new surface. Don't think we replaced the bearing on the output shaft from converter ---not sure?? Couldn't see that the broken flange really affected anything. Ujoint/output shaft don't seem to have any vibration to them. If its excess pressure I would have thought it would push the seal out and not just the rubber off the seal. Thanks for suggestions . Don | |
