Posted 4/18/2010 22:32 (#1166838 - in reply to #1166721) Subject: Re: JD 4730 sprayer issue.......
35 miles south of Houston,TX
I swapped the part of the flow meter that unscrews. The part with the sensor and the what I will call the "impeller". I do not know if that is the right term. We did not change out the part that remains attached to the sprayer. Just disconnected the pigtail, unscrewed the large "nut" and exchanged pieces. I will check the terminal connections in the morning.
