West Michigan | You need to get/give us more info. What is the manure test show for levels? How many gallons per acre were applied. If you did not send a sample away atleast whay kind of pigs and what form of pit. Sows vs finishers and ddep pit vs lagoon? These things make a huge changes in what you need to put on with it. We apply 4500 to 5000 gallons with wean to finsh deep pit wet dry feeders. And with that amount apply no extra N. Spread it three or four days before planting then work it in. I unhook the chain on the fert pump for the 2x2. Hog manure is almost all available the first year. Mine test out at about 95% first year. Manure sample will also show you what is available by testing the forms of N in sample. Need more info to answer your ? | |
