Posted 4/8/2010 11:04 (#1154824 - in reply to #1154680) Subject: Re: Ez guide 500 - Raven 440 variable rate .
Sw ontario
I guess I need to look at my maps and find out the max diference in rates and see if it is possible to get set up and keep pressures in check. I can change the pump setting to give me different ranges... but I"m not sure what my max difference in GPA might be ?? maybe 10 Gal maybe 15 who knows I will have to try setting different settings on the Raven rate swtich and flip back and forth and see what i come up with
