SW Iowa | I have the same setup. You have to have the foot switch it's your master switch. If you don't have it, the sprayer will spray when back into corners. Or when the boom swings wide outside the coverage map. Its easy to install and use. A sprayer has no height switch.
I agree with Greenfarmer on the NH3 and planter. When doing those I put the footswitch in the corner so I don't push it on accident and then wonder why things won't work. But a sprayer is a differant animal.
Rick
Edited by RJM 4/8/2010 08:22
