Binbrook, Ontario | i know for ours we used truck air brake tubing (3/8" and 1/4" i think) to go from keetons to sight guages. this way we could use the "tube lock" push-to-connect fittings which are actually pneumatic fittings. there are plastic ones that are safe for liquid fertilizer. they come apart and go together SO easily, the lines are much thicker and dont kink and then get those two nasty pin-sized holes on each side. i can also repair a line in the field in less than a minute with a pocket knife and a push on fitting. | |
