SW Minnesota | I would pull a tape on all of the skips, at least 6 in a row. Then look at what it is doing by drawing it out on paper. My guess is the same as dutch in that it is something to do with the implement width or implement off-set or a combination of the 2. I did have a stranage one something like this last year in one field that was just simply a problem of the way I set the ab line. I set a new line and the problem went away. I had loaded a line from the year before and did a nudge to line up the edge of the field. It planted just fine but when I came back to spray,(sprayer is twice the width of the planter) that line would not work. I set a new line and all was good. | |
