SE ND | Can i run an Insight or Integra alongside my JD 2600 RTK System in my planter tractor for the purpose of controlling my 09 John Deere planter with row command and doing variety mapping? The reason i want to do this is i want variety locator available in my Case combine this fall. I would be running the Insight or Integra in the Case machine only as the yield monitor-mapper. Everything else guidance, steering ect will be controlled with either the Deere system (2600) in the planter and the Trimble system (Pro 600, nav2) system in the fall. I would have to be able to feed the Ag leader display GPS data from either receiver. Is this possible? What kind of harnesses would be required in the planter tractor and would these be very expensive? What modules would i need unlocked in the Agleader displays? | |
