Hillsboro, AL | I have not worked with the Hagie, but had the same problems with a Patriot 3185. - Do the dead zone calibrations.
- Then raise the deadzones 1-2 points higher than they calibrate.
- From there work with the steering gain to fine tune. On some systems the steering gain can be very touchy and a quarter of a point will make a lot of difference. Try tune the gain at the speeds the sprayer will normally run.
