SE Iowa | you can use quite afew things Valor XLT at 2.5 oz, Sonic at 3oz, Optill at 2 oz if you can get it. These are my prefered ones to use becuase they are low use rate and they have great results. Valor is the lowest price but if you want to get away from using 2,4-D you can use Optill and it will help control the existing broadleaves. Optill is going to be on of my favoreties when there is enough supply. because I would have the risk of hurting the beans if I plant to close after spraying.
