NE Iowa | Connect Insight or Integra to existing sensors is $1600. No unlocks needed. Kit comes with all modules and cables needed.
If you are buying a new monitor than might as well get an Integra. The paradyme will hook into the factory accu-guide on the combine. You won't use the nav 2. The paradyme is the gps and steering controller built into one. Then you can move the system to your other machines throughout the year.
