Carter Montana | Those of wanting to replace your Insight with the Integra in Direct Command applications do not have to replace your display cable. Just plug it in and go. My case is a full sprayer DC kit with the LCM. No serial control or any of that. The exception to this is if you are planning on running the Paradyme or the Ontrack. In those cases you will need the display cable that comes with the Integra and cables 4001979-3 and 4002016-12. Oh, double check before ordering but I think I have this right.
Edited by mtbrights 3/10/2010 15:49
