central illinois | For the last 7-8 years I have been using a product from Helena called Request instead of AMS. In normal conditions it is mixed at 1 qt/100 gal,but if conditions are dry then the rate goes up. The last 2 years I have used a generic called Sequal and has worked with no problems. When I mix a tank I fill with 1/2 to 3/4 of the water and add the Sequal first to condition the water before adding the roundup. This product does not give any drift control.
