Posted 3/10/2010 18:43 (#1114154 - in reply to #1113984) Subject: Re: Connecting Raven Invicta 210 to Insight
Butterfield, MN
The -119 cable is shorter than the -272 cable. Either one will plug into port A or B, but the default settings for the ports are different. It doesn't really matter though, since either port can be set up do do the same thing as the other through the front panel of the controller.
