Posted 2/18/2010 20:34 (#1081413) Subject: 6v vs. 12v batteries?
Effingham, IL
My question is about cold cranking amps. I am replacing two 6v, 925cca batteries on a 4640 with two group 31 12v 925cca batteries. Does the cold cranking amps stay the same on the two 6v in a series vs the two 12v parallel? It sounds like from previous posts that the 12v's are definately better. Thanks! Craig
