Posted 2/19/2010 09:06 (#1082102 - in reply to #1082005) Subject: RE: SI Distributing sells a ramp....
The ramp helps center the seed after it falls off the disk (not sure if JD sells something similar). The 40 hole promax or SI Dist is the only solution for the older 2 hole box planters. With the newer planters you're probably better off with the PP parts.
