Classifieds (178)
May Need Larger 4WD To Pull Planter
Machinery Talk
Pat H
2/18/2010 09:20 (#1080707 - in reply to #1080646)
Re: May Need Larger 4WD To Pull Planter
You might look at some steigers:
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=5657699
(a little low on hp maybe
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=5611998
(needs the outer axle mount duals
Anyway, there might be some other tractors in the same cost range as the 8440. They may not have a pto or 3 point, but would pull the planter ok.
HTH,
Pat
Brian_nwIL
: 2/18/2010 07:11
RE: May Need Larger 4WD To Pull Planter
Versatile Farmer
: 2/18/2010 08:15
Cliff SEIA
: 2/18/2010 08:36
Pat H
: 2/18/2010 09:20
frseed
: 2/18/2010 09:24
Pat H
: 2/18/2010 09:30
mcfarm
: 2/18/2010 09:41
frseed
: 2/18/2010 09:56
bracketman
: 2/18/2010 09:55
JohnW
: 2/18/2010 13:17
