| Wire size will be determined by length and amp draw. You need to check on the pumps, and the number being run at the same time. Don't forget to allow for lights or other needs. I would suggest that you consider placing a battery on the trailer, near the load. If the battery will not run the pumps long enough before it needs a re-charge, you could run a smaller wire to it from the power unit to re-charge it while driving. | |
