21617 | You should be getting more than 3.9mph out of your 9670 with an 8 row. But with your bottom sieve so tight and your top sieve so open no wonder you're having trouble with the fines and have only been able to run slow. Running the shoe like that will overload the tailings in a hurry, try 15 and 15 and play with it +/- 5mm make sure your loss monitor is calibrated and make sure you know what all the greek symbols mean it helps a lot when setting the machine particularly the shoe. As for the rotor start with the slowest it will go and the concave as wide as it will go and begin to tighten it up until your cobs are clean without cracking corn. With an 8 row on that machine you should be running at least 5mph | |
