Posted 2/9/2010 06:56 (#1065519) Subject: 7200 Conventional vs Conservation
West Michigan
Can both a 7200 conventional and conservation be setup the same way for no-tilling? I know that the conservation has a heavier frame and individual lift cylinders. The row unit is the same, correct? I have not seen single disk fert openers on a conventional. You guys have a preference between the two?
