Posted 2/6/2010 13:50 (#1061233 - in reply to #1061194) Subject: RE: Will a JD 2510 run a 25kw pto generator?
SW Ohio
should work but I would watch the rpm's when under full load it might pull it down enough to change things. I have an Onan 25 KW alternator I run with a 2240 and if it gets pulled down too far it will change the voltage and the hertz.
