Posted 2/6/2010 10:39 (#1060977 - in reply to #1060958) Subject: Re: tru-cluches ? again
Dix (Boyd), IL
Remember that the clutches will turn off whenever they are "told" to. So you will need to find a controller that is capable of this kind of programming or timing. My only experience is with the JD rate controller. It will not do this. Other might be able to. So "yes" the clutches can do this if the controller can.
