| Our shop has a closed loop air sytem with 175psi. We have an air regulator settup to plug into one of the quick couplers in the loop , then the air hose plugs in to it,so that it can be used anywhere in the shop where we need to regulate air pressure. Also have a regulator permamently installed on the line that runs across the work bench.
With the portable air regulator we can use reduced air pressure at one drop & still have 175 psi at the other drops at the same time. Works good for us.
Edited by boog 1/22/2010 21:09
