Southern Saskatchewan | Well you wanted to know what I found.Took the fuel filter off and like it was mentioned only 1/2 full. Installed new filter,filled to the top and turned it over.Started up no problem. So I will check on the check valve,lines and hausing to make sure where the real issue is. At least it gets it dollied off and into the shop the easy way.Thanks guys it just confirms again why I visit this site almost everyday! | |
