| I think I would begin to question the "trusted" term for your alignment shop. I would take it back and have them do it correctly, or maybe a better choice would be to ask them who they would like you to take it to so that it was done correctly, at their expense. The turn signal problem does pose a concern, did it work before? The plastic parts are not that hard or pricey to replace, but I wonder how it happened to mess up while they had it. Did they pull the steering wheel by chance? I don't see that you messed up anything, from what you describe, I try to mark the tie rod ends and set the new ones at close to the same, but it's still a good idea to have a realignment done. | |
