Posted 1/19/2010 15:18 (#1030637 - in reply to #1030390) Subject: RE: Flexicoil 65 or 67 sprayer Good or bad?
west Nebraska northeast Colorado
Jake, How do you adjust hydraulic flow to sproyer pump, with flow control on tractor, with bypass on pump motor, or with both? Do you notice a pressure drop at sprayer booms when you throttle tractor back? Does sprayer controller compensate? What about using other hydraulic functions while spraying-do you notice any pressure drop? Thanks for info.
