Posted 1/18/2010 18:43 (#1029039 - in reply to #1029015) Subject: Re: Insulating a window
East Kansas, DeSoto
Fit foam as close as possible and then use some 2 inch clear tape and put around in the foam edge ion the inside in the form of 90 degrees. Would hardly show and finish the seal. Most sealants attack foam. Some of the modern clear tape acts like the stikums you ,mention. Gifford
