| Start using the eCBOT ... reduces brokerages fees, some as low as $4-5 roundtrip. Broker will provide realtime bid/ask through DOM, execute your own trades, then you are responsible for your fills and have no one else to blame. Roughly half the daily volume is done on the screen, no real advantage to using the floor EXCEPT when eCBOT crashes - has happened several times since side-by-side trading began. | |
