washington iowa | I run a 755 with the agri products tanks. I wanted the fast tanks at 850 gallon but the price was 80% higher for them. To make up the gallons I run a 400 nose. I put electric valves on the tanks with switches in the cab so I can control the levels of the three tanks. I pull a 24 row 1770 ccs with 600 gallon on the main frame and 200 on each wing under the markers. I also pull an Allsteer 1600 gallon. All these gallons are for nitrogen and pop-up. When I'm loaded I leave the nose till last to help with traction. The agriproducts people were great to work with. | |
