| I have this all figured out, the Super 10 has 11 to 1 ratio, the 13 speed has 12.56 to 1. With the rear end this gives an acceptable final ratio, the 13 speed will actually be better than If I changed the rear end. I talked quite a bit with a guy in the valley that builds beet trucks, he assured me this will make a whole new truck out it. THe transmissions are the same length no drive line shortening is needed. Should be pretty easy swap I am going to do the clutch while I am in there. | |
