Ohio | Seal all holes with dirt except for one. Use funnel and hose to pour gasoline as far down into the hole as possible. Stuff old crumbled up paper seed sack in the hole. Stuff it so it pretty much seals the vapor of gas escaping. This allows time for gas vapors to build inside of hole.
Wait for any lingering gas vapors outside of hole to dissipate. Light paper with match. Run. :)
You can also flood them out of their hole if you have enough water available.
Edited by jeffshelby 12/21/2009 00:37
