I think you would be ok doing as you said. It's pretty common around here to see white/yellow corn right across the fence from each other As far as how much distance to avoid cross pollination- kind of a loaded question because you can go in the middle of a quarter section of white corn and find yellow kernels on ears. But distance where you would get cross pollination significant enough to throw your sample off- probably the 12-24 rows you stated are good enough. |
