| YIELD DATA CENTER SHOWS RESULTS FROM OVER 540 PLOTS!
http://www.yielddata.farms.com
Canada’s largest on-line collection of canola, corn and soybean yield data continues to grow.
The Farms.com Yield Data Center http://www.yielddata.farms.com now has yield results from over 200 canola plots, 135 soybean plots and more than 200 corn plots. More results will continue to come in, so check the site each week to see the latest yields.
The site makes it easy for you to focus on the yield results that are most relevant to your operation. Click on the province of choice and select the crop and a company. This will take you to plot results for that company. Just above the first plot there is a maturity selection menu. Click on the maturity range that is applicable to your location and all the plots located in that maturity range will be shown.
We are also pleased to announce that canola yield data is now available from .
Before you consider taking advantage of early order discounts, check the local yield performance data at the Farms.com Yield Data Center http://www.yielddata.farms.com !
For more information, contact:
Peter Gredig
Farms.com
[email protected]
519-639-8180
