eastern ND | If the temps are right the snow seems to be blowing right through the combine. We started corn yesterday and there is snow on the plants, temps were about at 18 degrees and we had no problems. If your combine comes out of the warm shop when you start make sure that you run it for awhile to get everything cooled down inside or you will ice it up right away. A buddy is combining north of Fargo and they are combining soybeans and said that it was going good there too. Good Luck. | |
