NEMO | You dont say where its rusted out , but if its a heavy cast type ring I've cut a peice of flat steel to weld over the hole and then drilled it out to match the other gas holes. On a related note- if your gas pipe comes in from the top , the rubber grommet is probably bad and letting water into your burner and rusting it out -just caulk it up . I wish I'd figured that one out sooner. | |
